C207 Steering Wheel upgrade
Of course I removed the airbag from the round one to the flat one. Everything was plug and play..so I think its not a big deal to change it.
Is your car a 2013 C207? Since MB did not produce an AMG version that year, where did you buy your steering wheel?
Also, if you need to get a steering wheel with Up/Down/Right/Left 4-way buttons on the left side to maintain menu navigation functionality. If I am wrong, I hope other more "seasoned" members will weigh in to correct me
I intend to do this during the coming months, as well as the 12" Android upgraded touchscreen - also on CKM's site.
I currently have the steering wheel in the photo that you posted, and will be moving up to a more updated wheel.
I thought the left side controls had to have the 4-direction button layout (up/down/right/left)?
Does the toggle work to replace the up/down buttons?
you loose the lane assist function though. The feature where the steering wheel vibrates when you are out of line.
I'm glad to hear that the touch (joystick?) button works. This certainly opens up options.
So, in order to manipulate the COMAND menu, would the driver use the lower (non-touch) buttons and toggle (flip) button/switch? Does that question even make sense? If not, sorry.
Alas, I do not have the lane departure warning.
you have to use comand knob on center console
you can upgrade : all 3 of those options will require a new airbag (also plug and play)
w204 facelift
w205 prefacelift
w205 facelift (2020-2021 version)
the 2020 version wheel with an encoder will retain all button function except cruise control. those buttons on the wheel will be dead but cruise control will still work from your stalk.
all the other wheels will need a chip board swap from your original wheel that you can do yourself or you can find a company that will do that all for you. tons out there that can get this done. rucarbon, carismo, carbontastic;. shop around the prices are all over the place but those 3 companies are the best at what they do for plug and play compatibility that wont completely break the bank and are in the USA
w204 facelift
w205 prefacelift
Original steering wheel
So this is the current one I have, which I think they could have styled better. The outer wheel looks great but the inner tri spoke is just lacking. Shame though as the rest of the interior looks amazing. Which one do you have installed, can you share a pic of it?
