Hi All
I think my driver's side (right hand door) lock actuator has failed. The key fob only locks/opens the passenger door and the fuel filler flap. The interior lock switch also only locks/unlocks the passenger door. The actual key, when inserted into the door handle, is able to move the driver's lock up and down though so at least I can lock the car. The IR sensors on both doors work and enable/disable the car's security but only open/close the passenger door lock.
I used a code scanner and pulled a code off the RH door module. It was 98B101 with text of "The output for the central locking motor has a malfunction. There is a general electrical fault."
I'm fairly certain it's therefore the driver's door locking actuator motor.
Anyone else have any ideas - maybe it's something simpler? I've checked all the fuses they're all fine.
My VIN is WDD2073722F003179 - can someone tell me what the replacement part is for the RH actuator? Is replacing it a massive pain?
Cheers!
Ben
Cheers!
Ben
konigstiger
close
- Join DateJul 2003
- LocationNorth Scottsdale, AZ
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'71 Pinto
Liked:4,632 Times in 3,303 Posts
Right part # 2047202035, left 2047202135.
https://workshop-manuals.com/mercede...ce_and_repair/ + next page, see attachments.
204 o/s door handle, should be same for 207
- WDD2073722F003179.pdf (781.3 KB)
- install front door lining.pdf (1.02 MB)
- install crank window in front door.pdf (590.3 KB)
- install outer sealing rail.pdf (579.7 KB)
- Adjust crank window on front door.pdf (202.9 KB)
- Basic setting for front window.pdf (278.8 KB)
- Height adjustment of front window.pdf (542.1 KB)
- Adjustment of the preload on the front window.pdf (426.1 KB)
Currently Active Users (1)
