W207 Trunk/Boot Seal Issue
Old Aug 19, 2021 | 07:01 AM
hillek1's Avatar
w207 E220 Coupe
Hello All,
I recently bought my 2015 E220 Coupe W207 and have this strange issue with the top corners of the trunk/boot lid seal. Both corners are rusty under the rubber seal. Please see the photos attached. Anyone is having the same issue? What’s the reason and solution? Cheers.
Old Aug 19, 2021 | 07:55 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
I don't believe this is a commonly-reported problem. Perhaps the car was not garaged and leaves/debris were allowed to build up at the bottom of the rear windscreen and hold moisture there.
Old Aug 19, 2021 | 08:19 AM
hillek1's Avatar
w207 E220 Coupe
Thanks very much. I guess the seal needs replacing?
Old Aug 19, 2021 | 09:02 AM
Mr. Toad's Avatar
I would work on stopping the rust before worrying about the gasket. Unchecked, the rust will only continue to spread, even if the gasket is replaced.
Old Aug 21, 2021 | 12:05 PM
votnus24's Avatar
C207 E350 CDI
It looks like the rubber was stapled and the staples rusted. Remove the rubber and inspect if it the metal has been damaged.
Old Aug 24, 2021 | 03:39 AM
siepel's Avatar
Sold in 2026 - A207 E200 Cabrio - on to greener pastures
This looks like rust on the metal U-strip that is located inside the seal itself.
In such case I would not expect rust to be on the actual car bodywork (flange in the boot). Hopefully that seal can be exchanged by a fresh one?
Old Aug 25, 2021 | 03:48 AM
Harold1898's Avatar
2015 E400 Coupe
I have a 2015 and have no such problem
