2014 E550 Coupe Coolant Train Plug Location?
Old Aug 29, 2021 | 01:39 PM
911sc's Avatar
ml500
I have a 2014 E550 Coupe on which my coolant reservoir cracked I replaced the reservoir but wanted to drain the coolant when I removed the plastic cover underneath the car I can not seem to find where the screw or coolant drain plug is located on the radiator. Can someone please provide me with the location or a picture that shows where it is located. Thanks
Old Aug 29, 2021 | 05:36 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
Old Aug 30, 2021 | 03:01 AM
911sc's Avatar
ml500
Thank you very much for the information, just what I needed.
Old Aug 30, 2021 | 09:15 AM
Paul Shalom's Avatar
E400 W207 C320 W203
The Guru konigstiger Nailed it as always but here's a pic of the knob on the drivers side of the radiator that you turn to let out the coolant
Old Jul 28, 2022 | 02:50 PM
PhuongNguyen's Avatar
2013 E550 coupe
Won’t come out
I turned it to the left but it only goes 90 degrees. Scared to turn it more because if it breaks, whole radiator will need to be replaced.
