Help! Mercedes e550 steering wheel lock! Won't disengage!
I have a 2011 E550 convertible and the steering wheel and locked and will not disengage! It happened to me before and after a day kinda fixed itself and started again....this time no luck...any tips? Or should I just tow it and get them to replace the steering column lock? I can't shift into neutral to tow either so idk what I'm going to do! Any help would be appreciated! Thank you! Also sorry if this is the wrong thread!
When you put the key in the ignition, you can hear the motor unlock the column. If you don't hear it, it's dead. Try tapping/banging under the column near the dash, it might unlock the column when putting the key in the next time. Worth a try. The fix is much harder if the column is locked.
