How do I remove the left trunk liner
See the fluid accumulation
I have A leak on the right (passenger) side case cover lift cylinder. How do you remove this? I need To remove to send away to be remanufactured. Any help is appreciated.
I also noticed a little amount of fluid by the pump itself, unsure if both sides need it, but the passenger side has a lot of fluid. Any help is appreciated
--> Have you been able to identify the leak? How did you fix it?
All the cylinders look and feel dry, the only sign of a leak is a puddle of hydraulic fluid as in your picture...
From everything I've read online, the weak points are the main tonneau lift cylinders, so it "may" be this but I recorded a video with my phone in the boot whilst operating the roof and I can see the fluid go down but nothing coming out of the tonneau cylinder...
When you open the link above you can click the tabs I underlined in green at the top of the page of the photo below to navigate the different sections.
