2013 E550 Coupe w/Active Cornering Headlights
Old Feb 3, 2023 | 06:57 PM
The_Grimy_One's Avatar
2004 E320 Wagon / 2013 E550 Coupe
Hello.
I have a 2013 E550 Coupe and I am getting the following message:
What I am asking is, does this indicate that the headlight assembly is bad? When I called the dealer, they said there is only a low beam and a high beam bulb... And all bulbs seem to be illuminated. So would it be safe to say I need a new headlight assembly? Or am I overthinking this...
Thanks for any advice!
Old Feb 4, 2023 | 07:23 AM
ibbij's Avatar
Bi-Turbo E550 Coupe (W207)
I think the bulb that needs checking is the light with the orange cover on the side of the main headlight assembly. That might be the cornering light.
Old Feb 4, 2023 | 03:54 PM
konigstiger's Avatar
'71 Pinto
Provide VIN to confirm part #.
Old Feb 4, 2023 | 09:12 PM
Hello, the lights are from the following vin: WDDKJ7CBXAF043342
However, my car's vin is: WDDKJ7DB3DF187902
My car was in an accident and I used these lights when rebuilding.
Old Feb 5, 2023 | 10:02 AM
'71 Pinto
Part #s posted are correct.
File Type: pdf
Old Feb 6, 2023 | 09:11 PM
You are the man! Thank you. So what I am gathering is it should be the bulb listed as "50", an H7 bulb. Any idea if all these bulbs are easily serviceable?
Old Feb 7, 2023 | 08:19 AM
erich_aux's Avatar
2012 E350 Cab
On mine, there are little flap doors in the front fender wells that you can open to easily reach the covers that you unscrew to reach the bulbs. You’ll likely need to turn your wheels to provide more room for the door to open. If I recall, I found that easier on the driver side. On the passenger side, I was fine just opening the hood to reach it.
