What is this chirping/squeaking noise?
Old Oct 30, 2023 | 09:01 PM
jsizzles's Avatar
2020 e450
I have a strange intermittent chirp/squeak coming from my back drivers side tire that seemingly only happens on the highway at low speeds. Happens without braking which makes it strange.
here is a link to a video where it can clearly be heard:
https://share.icloud.com/photos/057kqnjaJxekKwgaIu8p9_TiA
Any ideas what this is?
Old Oct 30, 2023 | 09:40 PM
jsizzles's Avatar
2020 e450
https://share.icloud.com/photos/057k...kKwgaIu8p9_TiA
anybody?
Old Oct 31, 2023 | 07:36 PM
nkx1's Avatar
2010 E550 Coupe
No idea. You might want to post in the correct forum though. This forum is for the 2010-2017 E-Class coupes and convertibles. Good luck!
Old Oct 31, 2023 | 07:44 PM
superswiss's Avatar
2019 C63CS
What are you expecting anybody to hear with all that road noise and wind blowing into the microphone? That's all I'm hearing. I listened to it twice, but between all the background noise I heard no chirping or squeaking.
Old Oct 31, 2023 | 07:50 PM
nkx1's Avatar
2010 E550 Coupe
To be fair, it's probably kinda hard to record something like that if it only happens at speed and it's outside of the vehicle. I actually could hear the squeaking noise in my headphones; it sounds like metal-on-metal squeaking, but I have no clue what it is. This seems like a qualified mechanic situation.
Old Oct 31, 2023 | 07:54 PM
superswiss's Avatar
2019 C63CS
Must be above my or my headphone's frequency range.
Old Nov 2, 2023 | 12:43 AM
Chevota's Avatar
E550 Coupe 2wd (2016)
I can't hear squat, except mass wind noise.
You could try loading/unloading the suspension and parts, subframe too, to see if you can force the noise. If you hear anything or not the result will likely be same, which is you still don't know what the cause is. So you could skip all that and spray lube on all the moving parts. Lots of moving parts in there, so I guess WD-40 or maybe silicone spray? Silicone is really only for the rubber parts, like the bushings, but it will temporarily quiet metal squeaks.
It could be the brake too, maybe the caliper is bound up and dragging a pad, and that general speed range is just right to get it to squeak. If you can make it squeak steady then I'd very lightly apply the brake to see if that makes it go away.
