Siegmann
close
- Join DateSep 2018
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive10-second E550
Liked:103 Times in 91 Posts
I need to remove the partition behind the engine to get at the heater hoses closer to the firewall. Does anyone have a DIY procedure? Some other models have a removable section for access, but not the 207.
My leak appears to be coming from the piece that goes through the partition, so I'll have to disconnect from the other side to replace it.
Thank you
Thank you
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,802 Times in 4,785 Posts
Thank you
Have you made any progress? Originally Posted by Siegmann
I need to remove the partition behind the engine to get at the heater hoses closer to the firewall. Does anyone have a DIY procedure? Some other models have a removable section for access, but not the 207.My leak appears to be coming from the piece that goes through the partition, so I'll have to disconnect from the other side to replace it.
Thank you
I recall reading W212AMG ppl removing that firewall with 2x 10mm screws to work on engine rear end (PCV , HPFP).
Removing this partition seems like a good move!!
Heater hose plastic adapter is subject to cracking.
Siegmann
close
- Join DateSep 2018
Ended up pulling the cowl instead.. same as w204 procedure. I replaced the fitting that passes through the partition (which was leaking) but the BAD leak was the fitting on the back of the head that had separated. Had to remove the vac pump for that.Originally Posted by CaliBenzDriver
Have you made any progress?I recall reading W212AMG ppl removing that firewall with 2x 10mm screws to work on engine rear end (PCV , HPFP).
CaliBenzDriver
close
- Join DateApr 2019
here is the W212AMG LINK...Originally Posted by Siegmann
Ended up pulling the cowl instead.. same as w204 procedure.I replaced the fitting that passes through the partition (which was leaking) but the BAD leak was the fitting on the back of the head that had separated.
Currently Active Users (1)
