HELP: Will C43 AMG Wheels fit on 2010 e350 coupe??
Hello Everyone,
I just recently bought this 2010 e350 with only 50 000 km and I'm seeking for some advice on fitment regarding the wheels and some suggestions for tire sizing as well.
Thank you very much in advance,
I would like to keep the suspension stock
Current suspension and wheels: Agility Control damping system
Strut front suspension & 5-arm multi-link rear suspension
I don't have any tires atm, I would appreciate some suggestions for winter and summer setup. I live in Montreal and our roads are horrible, so especially for winter something with a little more meat would be safer.
Thanks again in advance for taking the time to read this
Current setup
Reason: no replies
If anyone has these on their Coupe I would welcome some pics, for some reason I only found 1 or 2 pics of sedans, no Coupes.
these sound like they should fit but did you see the massive fitment thread for the 207? I’m sure someone has ran this setup if not much more aggressive.
Congrats on your new ride. The offsets are extremely similar, so I can't imaging they wouldn't fit assuming that you keep the overall diameter the same or similar.
Those seem like really narrow 19" wheels (I'm surprised an AMG car would have such narrow wheels). And even though the offsets are similar, the rear wheels will be positioned 3mm further inward than your stock wheels (which are already pretty far inward). If you're saying the roads are crap where you are, I wonder if going with 19's is a great idea? It may be safer to go with 18's to lessen the probability of a damaged wheel.
Thanks for the feedback,
I did not see the thread, I'll def take a look
Thanks,
Regarding the size, I actually thought so too, I would have expected 8 or 8.5in FR and 9.5in rear. I think there are dif packages you can take to get wider wheels, but I found an awesome deal on these.
for the dimensions, I did go on WILLTHEYFIT and got the same result as you mentioned (diameter is slightly bigger), but I just wanted to be sure because I had bought another dif set for winter FR 7.5J X17 ET47 — REAR 8.5J X17 ET58 with 225 55 17 tires all around and the front was hitting the shock and the wheel could not turn at all with the car in the air.
I just assumed that someone had surely already used these or something of similar proportions on here and could also share their advice on fitment and best suited tires for them.
__ If you're saying the roads are crap where you are, I wonder if going with 19's is a great idea? It may be safer to go with 18's to lessen the probability of a damaged wheel.__
You're right, that's why I initially intended on getting 18, but could not find any. During the winter I will prob keep my 17s, but summer is alright if you drive carefully.
