stock 18 wheel fitment
Old Apr 27, 2024 | 02:44 PM
604550C207's Avatar
C207 550
Hey,
Been searching for wheels and learning lots from you all.
My 550 came with stock 18s, 235/40/18 and 255/35/18. I do not know the offset.
Wheels have some damage, so as time came for new tires so did my search for new wheels...
Budget isn't allowing for what I want and I stumbled across a set of nice condition stock wheels.
so back to the basics for me.
18 x 8.5 ET48
Just want to confirm that these will fit the 2010 C207 properly.
also, am I still limited to the 235 fronts and 255 rears, or can you put a 265s for the rears?
Old Apr 28, 2024 | 06:17 PM
damaro's Avatar
2012 E550 Cabriolet
Originally Posted by 604550C207
Hey,
18 x 8.5 ET48
Stock wheel size for the E550 with the tire sizes you have is:
Front: 18/J8 ET 45
Rear: 18/J8.5 ET 48
You should run the specs through a wheel configurator to confirm how much this may change (you can find them online) but I suspect they will be just fine.
I also suspect you can put 265 width tires on the rear but just be sure you aren't changing the diameter to the degree that your speedometer will be impacted.
Old Apr 29, 2024 | 01:10 PM
604550C207's Avatar
C207 550
Front: 18/J8 ET 45
Rear: 18/J8.5 ET 48
Thanks for the info. Did some reading on the potential speedometer issue. Learning everyday.
Sounds like 18s should be 235/40 fronts 255/35 rears and 19s 245/35 fronts 265-275/30 rears.
Old Apr 30, 2024 | 12:19 PM
604550C207's Avatar
C207 550
Dude sold the wheels.
The hunt and frustration continues.
