:0!! Oil filter cap new owner help!
Once you have the new one I let you get creative to get the old cap out with a filter top wrench.
Pumping oil out is child's play every 5000.Miles with a 9-Quarts manual extractor.
spring loaded plastic relief
genuine bypass valve
first point of failure
The key is a good clean filter plus low engine calcium sludge to partially plug-up filter then bypass relief will feed contaminants at every startup.
You can read the source thread here.
