Video - M278 Bi-Turbo 4.7 V8 Failed Engine Teardown
Old Aug 7, 2024 | 09:30 AM
jtb33's Avatar
2007 GL 450 (former) and 2012 E550 Coupe
Watched this whole thing. Thought it was really cool to see this engine taken apart.
Old Aug 9, 2024 | 03:59 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Let's see what caused this clean failure...
A piece of piston shaving ended spinning a con. rod bearing after contaminating clean oil circuit through filter bypass valve.
Old Aug 9, 2024 | 04:36 PM
jtb33's Avatar
44:50 if you want to skip to the "what happened" portion.
For me, I found the process of disassembling the engine and parts to be the most interesting. The "why" of the failure was secondary.
Old Aug 9, 2024 | 05:42 PM
Erik's dismantling video are always a lot of fun to watch !!
I saw this video already a couple month back.
M276/8 engines do not have any oil pressure nor temp sensors. The Bosch firmware is able to guestimate oil conditions...
