2011 E550- Thump from rear when accelerating
Old Aug 7, 2024 | 06:26 PM
brofls's Avatar
2011 e550 Cab
Only happens when driving over ~50mph. Pressing on the accelerating more than maybe 10% leads to a low sort of thumping sound from the rear behind/below the driver's seat. The harder you press on the accelerator the louder it is but it doesn't last if you keep your foot on the accelerator, only lasts about a second. Everything sounds completely normal at lower speeds though and if your foot is on the accelerator just enough to maintain the current speed this doesn't happen. Braking/decelerating sounds fine.
Old Aug 8, 2024 | 07:54 AM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Check drive shaft couplings and center support for damage or worn out. Also check the transmission mount and engine mounts. Replace as necessary.
