A207 headrest adjustment motor replacement
Old Nov 30, 2024 | 01:35 AM
Rihani's Avatar
Mercedes a207
I have 2010 a207 e250 cgi cabriolet with full memory seats. I want to change the headrest motor but i can't get it out of it's place and i don't wanna break anything... can anyone one help me and tell me the right way of removing the motor from its bracket.
Old Nov 30, 2024 | 07:01 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 coupe
See attached and let me know if this helps? I may need your VIN# to provide 100% accurate info. Happy to share other WIS files if needed?
File Type: pdf
Old Dec 1, 2024 | 01:17 AM
Rihani's Avatar
Mercedes a207
thank you but unfortunately that's not what i need...
I want to know how to remove the motor from the frame of the seat.
Old Dec 1, 2024 | 09:05 AM
Jaybird123's Avatar
Apologies, was a bit sleepy...see if this better suits?
File Type: pdf
Old Dec 2, 2024 | 02:53 AM
Rihani's Avatar
Mercedes a207
tha k you soo much for your efforts.. i managid to remove the motor.. there is a metal clip that u have to bend down in order to the motor to slide to the side.. after i installed the new one.. i bent the metal back to it's original place so the motor won't slide out of it's bracket..
thank u again
