E30 Fuel?
A negative side effect can be a fuel trim fault. E30 is right about the point where I was seeing an occasional fault here and there. The more Eth I added, the easier it would fault out. It made me nervous because when it faults the STFT goes to 0. No big deal putting around, and you won't even notice, but I was afraid that if I floored it may be lean. How/why I think that is a bit much to get into now, but I wasn't interesting is testing it. Restarting the eng resets the fault, btw. You can do this on the fly if you have key, but with the keyless go dealie you have to come to a complete stop >: |
To see your fuel trims you need a tool of some sort. If you don't have one I think you get setup for ~$15. Let me know if you want to do that, or have any questions and I can give you more details on any of this
Also, I have an Excel sheet to calc out mixing E85 with gas. Things like how much you need to add, what E# you ended up with in the tank, your actual mpg (not the BS dash reading) etc. Yours if you want it.
I'm saying it would be higher octane if you mixed E85 with 91 to net E30 of your own making. Because why would they use 30% eth and 70% premium gas when they can use 30% eth and 70% 84 oct gas? (I just googled it and found they apparently use 84 oct), If the pump E30 works, then great, but if you still ping then try mixing
Or maybe you don't care about ping, or power, but cost? If so, an E550 seems like an odd choice. If saving $ is the goal, just remember you have to compare actual mpg when comparing the two. I believe the dash mpg reading won't work with an Eth mix. It certainly doesn't on mine, which reads exactly the same on gas vs 50% eth, so I have do mpg manually.
