Perfect Wheel Specs for 2013 E550 Coupe
Old Jun 21, 2025 | 02:47 AM
The_Grimy_One's Avatar
2004 E320 Wagon / 2013 E550 Coupe
Lightbulb Perfect Wheel Specs for 2013 E550 Coupe
I am wanting to replace the 19" Mandrus wheels I have on my coupe.
The offsets for them are way too high.
19 x 8.5 +43 (245/35)
19 x 9.5 +53 (275/30)
My suspension is untouched, but I do have some H&R springs I may consider installing later.
I would like a more aggressive setup and will probably move to a 10" rear. I have also been considering 20s, however, I think I want wider tires than 20s will allow.
I am thinking something like the following:
19 x 8.5 +35 (245/35)
19 x 10 +52 (285/30)
Am I on the right path? I have been looking at wheels for weeks and can't seem to pinpoint perfection.
What setup do you have? Any pics?
Thank you for any advice beforehand!
Old Jun 23, 2025 | 07:46 AM
ibbij's Avatar
Bi-Turbo E550 Coupe (W207)
If you want your vehicle to have better ride quality then I recommend keeping to 18" wheels because anything more and your just introducing more vibration and bumps to the vehicle and cabin. Thicker sidewalls on a tire really do help ride comfort and if you are driving a lot then that does matter. Think about just getting a pair of the 18" AMG wheels that came with the vehicle in 2013. I'm sure you can get a set on ebay. And for tires you can go with 245/40-18 front and 265/35-18 rear - a bit larger than stock for the AMG wheels. I put Continental tires rather than Michelin, but for your preference you may want the Michelin. I did a post about that here: https://mbworld.org/forums/e-class-c...lin-tires.html.
Old Jun 23, 2025 | 02:44 PM
griza's Avatar
2006 CLS55 AMG Sold 2010 E550 Coupe totaled by mechanic, '13 SL550 I totaled it, 2017 SL63 current
I had 19's on my E550 for 7yrs, never had an issue with anything ibbij said. I live in Miami, you live in Phoenix, you will have zero issues with 19's.
Old Jun 23, 2025 | 04:25 PM
You wouldn't happen to recall the specs of the wheels you had, would you?
And yea, I am on 19s now. The offsets are just way too high, and the car looks goofy.
Old Jun 23, 2025 | 04:26 PM
I understand the concern, but with that mentality, you would be better off going down to some 15s or 16s.
I will definitely look into the Continentals, thanks!
