2012 E550 Codes P0016, P2377, P012D
Old Jun 26, 2025 | 10:07 AM
Sinister310's Avatar
2012 E550
Hello,
I have a 2012 E550 with 181K on it and it started giving me a hard start. It takes about 4 seconds to fire up. Usually its instant. I put it on a diagonstic and it gave me P0016, P2377 and P012d. Anyone else experience this and If there is any advise you could share it would be very helpful....Thanks in advance
Old Jun 26, 2025 | 09:28 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
Sounds like your MAP sensor is bad so it can't give the correct fuel to start easily.
I'd say use an app or device to see what the static pressure of the MAP is, and the cam positions at idle, so you can see if the faults are real, and what/where needs attention. The MAP sensor should be both cheap and easy to fix (per pix). The cam code is likely a sensor, and even easier to replace.
I don't suppose you check for oil in your ECU harness? If not you need to because that can cause a variety of issues, and maybe yours. Your age and mileage made think of it. If unfamiliar, it's a common issue with these engines. Just search here for "oil in harness". I also posted a fix for it here: https://mbworld.org/forums/gl-class-...ml#post8771425
Old Jun 26, 2025 | 11:24 PM
2012 E550
Thank you soo much!
I will be trying this....... Thank You
Old Jun 28, 2025 | 08:55 PM
77Tony's Avatar
2011 E-350 Coupe
Google: "2012 E550 P0016" etc., to see what comes up. Might also want to tag the search with "MB World" and see if others have a DIY thread already. Also YouTube typically has DIY tutorials that may apply. Code descriptions are easy to find but do you have the skill, tools, software, parts, etc., to DIY. If not you may want to search for a reputable MB indy in your area.02
Old Jul 10, 2025 | 06:39 AM
2012 E550
It was the intake cam sensor that needed to be changed
