Darned Hydraulic Leak - stuck soft top roof
Old Aug 24, 2025 | 05:03 PM
srp002's Avatar
2011 E550 Cabriolet
Hey all,
I'll submit a more detailed post in a while but for now the summary is that I developed a leak in the hydraulic line on the driver's side of the roof mechanism.
I've watched Car Wizard and Grey Trends videos. I've purchased the hydraulic coupler/repair kit. I've purchased the hydraulic fluid from Amazon. And I bought a lubricant suction gun at Harbor Freight. (links below for convenience).
The first time that I saw the leak the roof had almost completely opened. I was able to close it before too much mess was made.
I now need to open it enough to access the hydraulic line to splice in the couplers but it appears that the break in the line is sufficiently bad that it will not retract quite far enough. It's too fiddly in the confined space with the roof closed to properly repair the line.
You can see the bend/breach in the hydraulic line from inside.
Does anyone have instructions for how to manually open the soft top roof? There are a few how-to videos for how to CLOSE the roof but it doesn't seem as straightforward as reversing those steps...
Car Wizard video: https://youtu.be/HR0_XBIKVyg?si=fOG92vV6Ckc4gDpf
Grey Trend video: https://youtu.be/IeaYkq9uXoU?si=Fpiu6RBzGH1mYJ44
Cabriolet Hydraulics: https://cabriolethydraulics.com/hydraulic-hose-repair-couplers/
Amazon Link to Hydraulic Fluid: https://a.co/d/8ESvZVC
Harbor Freight link to Lubricant Suction Gun: https://www.harborfreight.com/lubricant-suction-gun-59513.html
Old Aug 25, 2025 | 05:53 PM
RealDonn's Avatar
2011 E550 Cabriolet
Maybe add enough fluid to use power, BUT wherever it's leaking can get dirtied. Try to protect that.
