window opens after being closed
Old Sep 1, 2025 | 12:13 AM
Colin 59's Avatar
2013 A207
Hi there all, anyone have a problem where the window slips open 1/4 in after closing up or when the door closes it drops the same?
thanks
Colin
Old Sep 1, 2025 | 12:03 PM
TexasMule's Avatar
2014 E350 C207
You need to "reset" your windows. Check your owners manual for instructions on how to do it.
Old Sep 1, 2025 | 03:24 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Use a scanner to "NORMALIZE" ie. retrain your windows.
Right now the door module ignores your windows.
These issues are usually associated with unstable ir low VOLTAGE conditions.
Be sure to "normalize" windows when voltage is near satisfactory (not a known flat battery).
Old Sep 13, 2025 | 09:08 AM
Colin 59's Avatar
2013 A207
reset worked after anfew tries, used the individual and also all windows sw. to reset. Not sure which one did it but closes and stays closed now.
thanks everyone....
Colin
Old Sep 13, 2025 | 11:54 AM
Canceling Voltage Chaos
the underlaying issue is unstable low voltage - The cure for that is a battery maintainer so called battery "float charger".
It helps by keeping up battery charge instead of multiple battery troubles.
Old Sep 14, 2025 | 09:12 AM
Colin 59's Avatar
2013 A207
thanks , yes I have one and my battery tested ok but after putting it on for a few days seemed to do the trick. Only drive this car a few times a week so looks like I need to keep it on the trickle charger more often.
cheers
Colin
Old Oct 6, 2025 | 04:40 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
This bit me several times, and it seems the pattern (for me) is when I disconnect the batt while the door is open. I assume when it powers back up it thinks that partially open position is closed?
Now I close the doors before disconnect and it hasn't done it since.
