2011 e350 Cabrio bad ESL need clarification on several issues.
First off I hope I am posting this correctly. I'm new here, so please forgive me if I am doing this wrong.
So I'm at my wit's end trying to tackle an Electronic Steering Lock (ESL) repair on my 2011 Mercedes E350 Cabriolet, and I could really use some expert input to avoid turning this into a bigger headache. I've devoured every YouTube tutorial out there on swapping the ESL motor, but the testing steps are a total mixed bag—some videos flat-out contradict each other, leaving me second-guessing everything.
Here's the crux of my confusion: Several thorough guides emphasize the critical window for unlocking the ESL *before* remounting it to the steering column. But then they dive into the initial power-up test with the ESL in an *unlocked* state, even though they started with a locked unit removed from the car. One guy insists you *must* return the lock to its pre-disconnect position before reconnecting power, which makes total sense to me. Yet I've spotted multiple videos doing the exact opposite, and suspiciously, those same creators often plug their emulator programming services if things go south. You can probably guess my skepticism here...
From my research, I've pieced together that if the setup isn't pixel-perfect during that first power-on test—if the NEC chip hasn't already bit the dust, or if one of those microswitches isn't flipped exactly as it was originally—the ESL (or worse, the NEC) is toast in no time. You might snag an unlock and a couple of starts (maybe two or three if you're lucky), but that's just delaying the inevitable meltdown. One article did show the correct switch positions based on whether the ESL was locked or unlocked, which was a helpful—but no one addresses my burning question: **Can I manually rotate the ESL to the locked position and set it there *before* sealing up the board and case?** Or, should I lock it the same way that I unlocked it in the first place, should I just roll it back manually to match?
On top of that, in my specific case, neither of the switches will latch and stay closed no matter what I try. Is there a trick to make them to stick? To my understanding, switch #2 should be in the "out" position if the ESL was locked originally. Or, once everything's reassembled, will manually turning the gear/ wheel with a pic to the lock position somehow engage it properly?
Any battle-tested advice from folks who've conquered this beast would be a game-changer—links to reliable resources or step-by-step clarifications are gold. Thanks in advance for helping a fellow Benz owner get back on the road!
Cheers,
Will
If I had nothing to go on this is how I'd look at it:
If the unit was locked and you cut it out, then locked going back together, how would the car know you did anything? Just another day for the car right?
If unlocked that means you had to disconnect the battery with the key On, right? Lets say you did that, but changed your mind 5 seconds later and reconnected the battery. I'd assume it simply works fine from that point on because it would be weird if doing that kills something. I'm pretty sure I pulled the batt cable once with the key on by accident.
If so, and you remove it unlocked, then repair or replace it and put back in unlocked, how would the car know the difference?
So either scenario I can't imagine an issue? I'd do it that way if it were me.
Another thought is I can't imagine Unlocked not being ok, regardless of how it was removed, considering they have to be unlocked to install. Just an assumption on my part, but seems dumb the MB tech would have take the thing apart, that isn't really designed to be taken apart, and rotate it by hand without screwing anything up, then reassemble. Doesn't sound like German engineering to me at all.
Fyi I would never reinstall that ******* in any car I owned. I'd just zip tie it to something so I could easily access it next time from underneath.
I think the emulator is an excellent idea, plus I'd assume there are no worries and you just plug it in and go? It's a shame they're so much work to get done.
Whatever happens, please tell us about it so the next guy knows.
