Replace Key Battery Message
Old Mar 25, 2026 | 09:44 PM
pl626's Avatar
2015 E400
My 2015 E400 Cab has two sets of keys, the battery voltage in both were over 3v, but on fob would trigger the 'Replace Key Battery Message'. I used Energizer Lithium C2025s in both fobs, but only one would trigger the message. I tried swapping the batteries, and but the fob I use daily would not clear that message. Then I read somewhere that these fobs are very finicky and they seem to work best with Panasonic batteries. I ordered the Panasonic batteries and as soon as I put the Panasonic in, the red light on the fob worked and no more message. Crazy...
Old Mar 26, 2026 | 07:35 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
That's wild. I've never used any specific battery brand (whatever's available/cheapest), and have never experienced the issue you describe.
Old Mar 26, 2026 | 09:13 AM
hameline's Avatar
E350; GLK 350 4MATIC
Smile Voltage is voltage, dumkopf....
Welcome to the world of MB precise electrical parameters. So many weird things can be traced to voltages being slightly off in MB vehicles. If only all issues were so easy to correct!
Old Mar 27, 2026 | 10:16 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
I wrote a whole spiel about having the same issue, and short batt life. My fix was to charge the batt to a higher voltage, like 3.45, and problem solved. I also modded the key to take a bigger 2032 batt.
If the batt dies early, and you want to try my way, search for my post.
Old Mar 28, 2026 | 06:40 AM
pl626's Avatar
2015 E400
It's not necessarily brand, it's more min voltage and drain. The Panasonics are known to be over 3.2v and don't drain as fast. My other batteries, were over 3v but not quite 3.2. Really quirky spec, not sure if it's really documented anywhere but buried in a forum or YT. The main issue is if the fob no longer shows a red light when you press a button, you know the voltage has dropped below 3.2 and you need to replace. I can't explain why the Energizers worked for my spare key, i.e., red light worked and car recognized.
