Need Some Help On :Service Required, Do Not Shift Gears Plus ALL Fault Lights On
Hi Guys, need some help on this one. My wife was driving and all at once the car threw the following display Service Required, Do Not Shift Gears, Service Required, plus a ton of other indicator lights as seen in the video. She was able to pull over and no problems there. The engine was running fine, no noticeable sounds, belt is fine.. We read a few comments it may be a battery so already replaced and still showing the following in the video.. Any help would be awesome...
Received 2,512 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Sorry to hear about the issue, hopefully the forum members with the same car as yours are able to help you out here: https://mbworld.org/forums/e-class-c...brio-a207-141/
