E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Coolant temperature gauge
Old Jun 18, 2022 | 09:40 AM
splunge's Avatar
2025 CLE 53 Cabriolet
Just picked up my E450 cab and find the coolant temperature gauge has been replaced by a 48v charging status gauge .
Is there no way of displaying the ongoing coolant temperature without going into the engine menu ?
Old Jun 18, 2022 | 10:59 AM
W205C43PFL's Avatar
I don't remember if they also changed this for your vehicle with MBUX but in the pre-facelift with COMAND, it used to be in the "Service" menu on the driver side display, that one that you navigate into in order to check how long till your next maintenance is due, tire pressure (including resetting and accepting new reference values), oil level (for vehicles that don't have dipsticks) and coolant temperature level.
Old Jun 18, 2022 | 03:20 PM
teksurv's Avatar
2024 EQE 500
I also can't speak for MBUX, but for COMAND, the temp gauge is present on the main display where speedo/tach etc. is.
Old Jun 19, 2022 | 07:25 AM
MikeO3's Avatar
2018 E400 Coupe C238
You can voice command "engine data" as I recall there maybe the temp is there also.
Old Mar 19, 2024 | 11:28 AM
mjkarin's Avatar
2023 E450 4-Matic Cab
I have the same question. And, where is the engine menu?
Old Mar 19, 2024 | 02:00 PM
splunge's Avatar
Select ' Info' and then ' Engine ' and there is a full display of everything including coolant temperature .I just keep that display on permanently as my default setting .
Old Mar 21, 2025 | 12:33 PM
natesamg's Avatar
2020 E53 AMG Sedan
very normal. around the middle of the gauge is where it's supposed to be
when driving on the highway you have a lot more airflow over the radiator which is what cools down the water
