E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
EQ Boost Question...
Old Sep 22, 2023 | 02:39 PM
p.morrissey's Avatar
2012 E350 Coupe
I currently have a 2012 E350 (C207) since 2016 and I'm looking to upgrade to a 2019 to 2021 (C238).
Coming from a non-turbo 3.5 L engine, I'm curious if anyone has had issues with the EQ Boost system in the current E450?
After doing the research, the 48-volt beltless system seems like an upgrade, but I'm wondering about reliability.
Old Sep 22, 2023 | 09:12 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
No problems after 18k miles on my 22 E450 coupe. EQ system works seemlessly
Old Sep 23, 2023 | 07:08 AM
ktw13's Avatar
E53 Cabriolet
2021 E53, no issue with 48v system.
I do keep an eye on the 12V battery in the boot to make
sure it is healthy and does not drain the 48v battery.
Old Sep 25, 2023 | 09:37 PM
C280 Sport's Avatar
MB’s of all kinds.
Lots of issues with early EQ batteries but they have been replaced by now so you are in the clear! The system is excellent! It was an issue over in the CLS, GLE and GLS. Due to the lack of E Coupes made the issue is even less common. Also, it will be under warranty depending on miles being a 2019.
Old Sep 25, 2023 | 10:10 PM
chassis's Avatar
2017 GLE350 4MATIC
You are coming from arguably the most reliable MB engine ever produced, to a troubled 48V system. The battery and battery management system for MB's 48V system on several vehicle platforms has been problematic. If you have a warranty, the only cost is your time and aggravation. I would not own an MB 48V vehicle, with or without a warranty.
Read the posts above about early 48V builds. You are targeting an early build, and a pandemic build. MB fared worse than other car companies during the pandemic. Don't do it.
Old Sep 26, 2023 | 08:27 AM
2012 E350 Coupe
Thanks for your insight. I have had BMW, Audi, Toyota, and a few others, and this Mercedes 3.5 V6 has been the most trouble-free.
Old Sep 26, 2023 | 11:38 AM
lbowersaz's Avatar
2022 AMG E53
No EQ issues here.
Old Sep 26, 2023 | 03:13 PM
gmt58's Avatar
none
22 E450 Coupe. No issues at 15,000 mi
Old Oct 9, 2023 | 01:16 AM
Method320's Avatar
2021 E450 Coupe
2021 e450 35K miles, zero issues
Old Oct 9, 2023 | 10:48 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
2019 E53 coupe. Zero battery issues at 88k miles.
