E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
E450 Coupe Fuel Filler Door Tire Pressure
Old Mar 18, 2024 | 10:50 AM
hokietx's Avatar
E 450 Sedan 2022
The other day I realized 245/40R19 tires are listed in two places on my fuel filler door.
Wondering if the second listing pertains to using 245/40R19 on front and back?
I currently have 255/35R19 front and 275/35R19 rear (what dealer put on the car when I bought last year), trying to decide what pressure I should be using front/back for normal load.
Old Mar 18, 2024 | 01:59 PM
W205C43PFL's Avatar
It is a good idea to follow the tire pressures of the fuel cap just make sure it is checked when the tires are cold (so overnight or a couple of hours at least stationary).
Depending on your driving style and load, adjust up or down a PSI of such tire pressure, if you anticipate cold temperatures or warm temperatures in the coming days, also adjust accordingly.
Old Mar 18, 2024 | 02:50 PM
hokietx's Avatar
E 450 Sedan 2022
Yes, this is what I want to do.
Guess my specific question is if my front tires should be 33 using the first tire section.
Original front tires were 245/40R19 and are listed in first section at 33 and second section at 35 for normal load.
Old Mar 18, 2024 | 04:11 PM
W205C43PFL's Avatar
Yes that is fine for the new tire size.
Old Apr 2, 2026 | 12:07 AM
Lobsterotter's Avatar
E450 C238 2022; 300E W124 1993
Old Apr 7, 2026 | 01:38 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Disregard the sticker suggested tire pressures. They are set too low to sell you more Tire$$$$ & Rim$$$$.
(OR) Run around 38-40 PSI. Your tires will last longer, your rims won't bend & crack as often, fuel consumption will be less and you can cruise above 100+ MPH sustained (if needed) with less fear of a blowout.
If you don't mind spending money, as most MB owners fit that profile, enjoy the smoother ride 28-32 PSI provides you... then forget about the rest
