E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
A238 Wheel Spacer Size
Old May 3, 2026 | 12:48 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
I was interested in installing some wheel spacers. Our 2018 E400 Cabriolet 4-Matic has the 18" stock non-staggered wheels with stock 245/45/R18 sized tires.
Has anyone had success with any sold as a kit of four spacers with the lug bolts included?
If so, what size would be okay to run without rubbing, handling issues or excess ware to the suspension components?
I'm reading Hub-centric type 5 x112 pattern with 66.6mm hubs spacers possibly sized at 12.5mm rear w/ 15mm front or 10mm rear w/ 12.5mm on the front, Seems some of the kits are sent out and folks are finding out some don't fit the front or rear or vice-versa. I don't know if it's because of the 4-Matic or larger front brake size or something other third thing. Thanks
Old May 6, 2026 | 12:58 PM
Quess I could go with slightly wider 255/45/18 tires next time over the stock 245/45/18 run flat Goodyear tires for a bit of a wider looking stance as well if they would clear.
