key won't turn past glow plug notch
Any experience will be gratefully accepted.
Connie
Raleigh
A couple of weeks later, in PA, I couldn't turn the key at all and had to have the car towed to someone who wound up knowing a lot more than the guy in Raleigh: he said there are 3 dependent parts associated with the lock cylinder and since the car is 22 years old, he replaces all 3. The guy in Raleigh just replaced the cylinder. Since the key wouldn't move at all, everything had to be drilled out. The labor, plus additional parts, was over $400.
For me, the lesson isn't to replace all 3 parts next time, the lesson is to find a mechanic who thinks. I have a new mechanic now. Time will tell!
Connie
Connie
To get you home in the mean time, pull the lock cylinder and use some long needle nose pliers. Those will get you to pinch the sprung bits together and turn the ignition to start the car. You can use a bit of brute force since you won't be bending up expensive keys.
I replaced the module (ignition? security? I don't remember, I'm still scarred from that replacement) that connected to the steering wheel lock at the same time.
