AC troobleshooting help
'85 300TD Wagon 152K,'01 E320 Wagon 44K
Okay I have a question about my AC vent system in my 85 300TD Wagon. It has the California Emission set up. (I don't think this fact pertains to the vent system but you never know) I have double checked all the vacuum lines under the hood associated with the climate system -- everything checks all connected no leaks or cracks.
Here's the issue: My 2 outside vents, blow air like it's their job, however
the center two vents don't blow air, very weak at best. This occurs whether I turn the AC or the heat on, or even the vent "EC".
Is there a pressure diaphram somewhere or a vacuum line I'm overlooking that could be limiting/restricting airflow to these vents?
Any experience on this topic would be greatly appreciated!
The Rookie Kevin
The Rookie Kevin
I am not familiar with the setup on these cars. but i'd like to help!
the vents etc back in the dash, are they actuated by vaccum, manual lever/rod of some sort or electric?
with such a problem I wouldnt be looking in the engine bay, it'll be back in behind your dash at the air routing box. chances are (if its setup like every other car) one of the flaps isnt opening up all the way.
and I don't think youre stupid, but be sure the vents are open in the first place! (the little turn dial, beside the vent) haha
1980 MBZ 300SD, 03 Audi A8, 97 Volvo 960
The Rookie Kevin
The Rookie Kevin
