E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Gear ratio and speedometer correction
Old Feb 15, 2011 | 09:48 PM
Mr.RadioActive's Avatar
1973 220D
Thank you greatly for having me as this is my first post on this forum. I'm a lover of all MB. My collection of MB, SLK 55AMG, 69 220, 73 220D, and a E500.
I have a question. My 1973 220D came with a 3.69 rear end. It was changed to a 3.07 W123 rear. Now my speedometer is way off. Is there a instrument cluster out of a MB that I can swap mine out with that will make the speedo more accurate. Even closer if not 100%. Now the speedo is fairly useless.
Please help, I've searched and searched for the answer but haven't came up with anything.
Old Feb 26, 2011 | 11:19 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
A 220D has a 3.92 diff.
No W115 used a cluster with anything close to that ratio. A 3.46 from a W115 300D is about half in between the spread but its still too far off to be of even slight use.
The only option is to find a cable ratio box to overdrive the speedo. But you're looking at over $150 for one.
http://www.generalauto.com.au/Ratio.htm
