E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
1985 300d vaccum lines in door crevice cut
Old Sep 2, 2011 | 01:42 AM
chiltonw's Avatar
Mercedes 300d turbodiesel
The door was changed and whoever did it cut the vaccum lines....they are very rigid and I am wondering if anyone else has found a way to reconnect cut lines...right in that tube where they go through the door!!!!
Old Sep 10, 2011 | 09:05 PM
Outre's Avatar
83, 300D Federal
You just get some Vacuum Hose that fits tight over the Plastic Tubing and slide it over both ends of the Tube; the Plastic Tubing is color coded so it should not be too hard to find the ends.
If you have noticed that is how the Plastic Vacuum Tubing connects to the Components at the end of the Tubing; with short pieces of Rubber Vacuum Hose.
