Help! Problem starting 1978 240D
However even after changing all filters (to be safe), doing a diesel purge, replacing the manual fuel lift pump, and checking the pump lifts fuel to bleed screw, inlet to filter, outlet from filter, fuel return from injection pump and from each of the injectors at the head we still can’t get the car to start without using a starter spray in the inlet.
So - any suggestions on what we should look at next? I’m loathe to change the injection pump unless that’s the last resort - but it’s such a simple set-up I can’t think of anything else to look at?
James
The car didn’t start with diesel purge. It only fired up with starter fluid being sprayed down the air in take. Diesel is normal diesel - nothing bio or veggie.
james
There's supposed to be a clear plastic fuel intake screen between the chassis fuel pipe and the injection pump ~
It must be clear and have no crud in it and when you disconnect it as long as 1/3 tank of fuel, fuel *must* come pouring out of it .
Check this first .
If no free flow of fuel look under the ca, the tank to body flex hose may well be rotted (cracks) or clogged .
Sometimes the in tank screen gets clogged, it's a nasty, messy job to remove it but simple and easy to clean the screen .
If the 3MM fuel return hoses between the injectors are weepy, that too will make the engine impossible to start, hard to diagnose without being there to see .
