E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Replaced Engine Mounts- Still having bad vibrations
Old Nov 20, 2024 | 01:00 PM
Rice300D's Avatar
1981 300D, 1973 450Sl, 2007 E350
Hello,
We replaced my son's engine mounts on his 1981 300D, but there is still a lot of vibration and noise while driving. The engine seems to be running correctly. Would the transmission mount be able to cause that much of an issue? What is a test or trick to figure out what it is? I appreciate the advice.
Old Nov 21, 2024 | 04:41 AM
ygmn's Avatar
2015 E400 Sedan
tranny mount..
when does it occur while moving or all the time?
If moving check prop shaft, joints and center hanger thingy if it has one.
Old Nov 22, 2024 | 01:21 PM
Rice300D's Avatar
It vibrates more than normal at idle but not terrible. I have a 1981 300D as well, so as compared to mine. But it is much worse in gear and driving.
Old Dec 17, 2024 | 12:39 PM
Heavenseyes's Avatar
1984 300D
Sounds like driveshaft rubber center bushings. Easy fix.
Old Apr 12, 2025 | 11:54 PM
yyce400's Avatar
E400 Wagon
I just did my engine+trans mount as well 2 weeks ago. I felt the improvement was substantial one the first drive, but it faded after a while. It could be you've adjusted to the new normal of the car? My start/stop would literally jolt my whole care, now it's quite smooth, so I can definitely see an improvement there.
