New Guy
The MercedesShop team has done the research to identify all the parts necessary to convert a 300E/E300 to Sportline suspension specifications. In addition, we have sourced the OE parts and can provide the entire kit through PartsShop for around $1,350. These parts include the following:
Front Springs
Front Struts
Front Sway Bar
Inner Bushings
Outer Bushings
Lower Control Arm Bushing Kits
Rear Springs
Rear Shock Absorbers
Rear Sway Bar
Rear Bushings
Rear Sub-Frame Mounts
The M103 3.0 liter inline 6 engine in the 1986-1992 300E's displaced 2962cc's or 180.8 cubic inches. While in SOHC 2 valve per cylinder trim it made 177 horsepower @ 5700rpm and 188 lb-ft of torque @4400rpm.
Yeah, our cars start in second gear. It'll start in a lower gear when you push down on the kick down button behind the gas pedal.
There is a kit out there from bergwerks that would always make you car start in first gear, but since they closed down, I'm not sure if you can get it anymore but I would like to get it.
Is the plug located by the power steering resevoir? Someone taped the ends together, so I wasn't sure if that was the right one I was about to take out.
I thought you get bad gas mileage too.
