Does 15" look too small?
Old May 28, 2005 | 03:34 PM
jrmd01's Avatar
2005 E320 CDI
Old May 28, 2005 | 04:01 PM
X03's Avatar
X03
MB 1990 300E
kind of...but your car being lowered makes up for it
Old May 28, 2005 | 04:38 PM
AMG_Fred's Avatar
Mercedes-Benz w124
quite small. that is lowered a lot. i say get 16's or 17. 15 is too small. and those look like they are actually on yoru car and not photoshopped... i didn't even know they made 15's ( im barely starting out with this benz stuff ) 15 = no
Old May 28, 2005 | 05:18 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
15's look tiny. go for 16" with 205/55/16 rubber
or 17" with either 215/45/17 rubber or 225/45/17 rubber.
16" go with 16x7.5 with an offset of 35
17" go with 17x7.5 with an offset of either 37 or 35.
18" can be done, but since your car looks pretty much slammed, you will most likely have lots of rubbing issues.
AshMan
Old May 28, 2005 | 05:22 PM
hal's Avatar
hal
does 15" look too small
i think they look great. I have 94 e320 coupe sportline that they would look great on if you don't want them
i'll buy them
Old May 28, 2005 | 10:48 PM
CDP's Avatar
CDP
W124's
Your car definitely looks slam. What suspension are you running? I would definitely stay away from the 15" size....why go with stock size?
I'd either go with 17's but personally I'd go with 18's but that's just me.
Attention: I hit post count 1,000 with this post.
Old May 29, 2005 | 03:15 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
man please... either im dumb or really tired but that lookes photo chopped to me... look at the side skirt.. wtf is that?
Old May 29, 2005 | 12:12 PM
jrmd01's Avatar
2005 E320 CDI
I hope I didn't mislead anyone, maybe I should have mentioned that the photo is indeed photoshoped. The car and rims are real and on my car.
The drop is fake. I was just looking to see if my 15" look to small even after dropping it. The drop I'm planning will be similar to the setup ChrisDPham has... votland springs, #1 pads all around, and speedybenz camber arms.
My intensions were not to deceive anyone, just wanted comments on my wheel size. I apologize if this offended anyone.
Anyway, I'm debating on whether or not to get 17" wheels. If the car looks O.K. after dropping it, I might just stick with my 15" wheels. My dad has a friend who gives him 14" & 15" tires for $5 each. He owns a tire shop and every now and then he gets very good tires as trade-in. The other sizes are not commonly used as trade-in (or they're worn out so badly, especially on the inside because of bad camber). So for the past 4 1/2 years I've only spent $40 on 8 tires. If I upgrade to 17" then I'll be spending over $100 per tire.
Again I apologize for any misunderstanding.
Old May 29, 2005 | 02:02 PM
AMG_Fred's Avatar
Mercedes-Benz w124
there are more things to consider than just tire diameter..theres width and how much tread will be left.. will it be an all season tire...?
Old May 29, 2005 | 02:12 PM
CDP's Avatar
CDP
W124's
I think you over exagerated your drop. Since you want the same set up as me. You won't have that same low drop. I'm running stock 15" wheels with 205/60 series tires and mine is no where near that drop you photoshopped.
Then again...why keep stock size tires? Go big and go 17's and if you can 18's.
Old May 30, 2005 | 06:42 PM
hal's Avatar
hal
does 15 look too small
again if you let these guys talk you into changing wheels to a larger size.
i would be interested in buying your wheels.
i have a 94 e320 coupe sportline that 15" wheels would look great on cause the sportline option already took care of the lowering and the quicker ration sportline steering is noticeable from non sportline cars
Old May 31, 2005 | 01:40 PM
jrmd01's Avatar
2005 E320 CDI
Actually only the drop is photoshopped, but everything else is real and on my car. (I should have mentioned it in the original post)
Whatever tire/rim size I go with, it'll be for "all seasons". I live in Hawaii, so we only have 1 season...summer. If I go with 17", I'll take ashman's advice on the tires.
Originally posted by ashman:
17" with 215/45/17
This is the size I'm going to go with if (or when) I get the 17" wheels
Originally posted by hal:
if you don't want them i'll buy them
Thanks for the offer to buy hal, but even if I go with a larger size wheel, I might hold on to these wheels as spares.
...I think you over exagerated your drop.
There's really only 1 reason I want to stick with the 15". I get my tires ALMOST new for $5 each.
Yeah, looking back at the pic, I should have been more realistic. Hmmm, you mentioned you car are still on the original 15" wheels. I wonder what you car would look like with my wheels/tire combo...
Yes you're correct...I should have mentioned it in my orginal post. I posted a follow up. Sorry if you were offended.
Old May 31, 2005 | 03:07 PM
CDP's Avatar
CDP
W124's
Since you're going for the similiar set up as mine. Your car will probably be going to look like mine with the stock wheels and tires.
