alignment for '94 e420
Old Jun 9, 2005 | 12:26 PM
cho260e's Avatar
2008 E320 Bluetec / 1994 e420 (totaled) / 1997 SL500 / 1991 300SE / 1991 300e 2.6 (sold)
Question alignment for '94 e420
Hello,
Does anyone have good specs available for align front & rear on my 1994 E420?
Thanks!
Old Jun 11, 2005 | 08:13 AM
ksing44's Avatar
2010 VW Golf TDI
"Sport Suspension"
I have the alignment specifications from when my 1995 E320 was aligned after I added the Eibach springs. The Porsche race-tuner mechanic found specifications for Mercedes Benz, 92-95, 124.034, “Sport Suspension”. I like the idea of tuning the suspension to the performance (Sportline or AMG I suppose) side of the specifications. I also asked to have the rear camber adjusted to within the same range as specified for the front camber. I figured the rear camber wasn’t specified because it isn’t adjustable from the factory, but I installed the K-MAC rear bushings so that it could be adjusted.
Front
Camber: Min -1.33, Nominal -1.00, Max -0.83, Actual Left-1.2, Actual Right -1.1
Caster: Min 9.92, Nominal 10.42, Max 10.92, Actual Left 10.5, Actual Right10.1
Toe: Min 0.08, Nominal 0.17, Max 0.25, Actual left 0.09, Actual Right 0.08
Cross Camber: Min -0.33, Nominal 0.00, Max 0.33, Actual -0.00
Cross caster: Min -0.50, Nominal 0.00, Max 0.50, Actual 0.8
Total Toe 0.17 0.33 0.50 0.18
Rear
Camber: Actual Left -1.2, Actual Right -1.3
Toe: Min 0.13, Nominal 0.21, Max 0.29, Actual Left 0.14, Actual Right 0.15
Total Toe: Min 0.25, Nominal 0.42, Max 0.59, Actual 0.29
