Clanking noise when I turn right...what now???
Old Aug 3, 2005 | 08:43 AM
abentley79's Avatar
87 300E
Clanking noise when I turn right but seems to go away when I turn left. Doesn't happen at slow speeds. I can't tell if it is the front or the rear Would this be a bearing or could it be ? something in drive ? IT continues to occur when I throw it in nuetral while turning. I am about to order a bunch of parts and would like to have this problem taken care of while I do all my suspension work.
Thanks.
Old Aug 3, 2005 | 10:44 AM
EKL's Avatar
EKL
1995 E320 Cabriolet
Have you check your Engine Mount?
Old Aug 3, 2005 | 11:16 AM
mike690003's Avatar
ex 300E driver
It sounds likr you need to replace your ball joints. it is a vey common issue on the W124's.
Old Aug 3, 2005 | 02:15 PM
abentley79's Avatar
87 300E
Ball joints looked ok
If the ball joints were bad wouldn't the rubber on the outside be cracked? Or could they be messed up even if the rubber seal looks ok?
Old Aug 3, 2005 | 09:53 PM
abentley79's Avatar
87 300E
Answer: What is an engine mount? YOU WIN!!!
Well this picture explains it...just one more thing to add to the list for this weekend:
Eibach springs
Replacement of every bushing and link and subframe mounts on the rear end
DRINK BEERs!
Weld engine back to engine mount!!!
Attached Thumbnails Clanking noise when I turn right...what now???-cracksm.jpg
Old Aug 3, 2005 | 11:02 PM
mike690003's Avatar
ex 300E driver
Wow!! that's not good at all. Did you run something over?
Old Aug 3, 2005 | 11:30 PM
AMG_Fred's Avatar
Mercedes-Benz w124
i think it was his mom... she wouldn't let him go out after 11 anymore.... good luck getting it fixed!!
Old Aug 4, 2005 | 01:01 AM
EKL's Avatar
EKL
1995 E320 Cabriolet
Ha ha ha...good old Engine Mount! You should able to pickup a pair under $80.00 But labor may run you about $200! Good luck!
Old Aug 5, 2005 | 11:42 AM
abentley79's Avatar
87 300E
Engine Mount bracket, not engine mount
The engine mount bracket is over $100 and its not in stock, so I think I can just wend that one back together. I just still don't understand how this could be causeing waht sounds like a bad CV joint...can somone explain?
Old Aug 5, 2005 | 12:38 PM
AMG_Fred's Avatar
Mercedes-Benz w124
if its just welding and putting it on... then im surprised.. i remember hearing somebody on mbworld.org ( just replaced, didn't weld anything ) that he replaced his in like 10 minutes
Old Aug 5, 2005 | 03:08 PM
abentley79's Avatar
87 300E
Have to weld because bracket cracked
The mounts themselves look ok. There is a bracket that is bolted to the engine and this is what actually is bolted to the engine mount. It is that bracket thaqt cracked somehow.
Old Aug 5, 2005 | 04:32 PM
EKL's Avatar
EKL
1995 E320 Cabriolet
The engine is mounted through two rubber hydraulic mounts at the front and a rubber mount with rebound stop at the rear. My understanding is the hydraulic failed from time to time.
I got my engin mount here: http://catalog.eautopartscatalog.com...t=Engine+Mount
