Turn for the worse
Old Aug 3, 2005 | 06:02 PM
Nick_M_51988's Avatar
1992 400E (86 300E, 98 S420) - Retired
Angry Turn for the worse
The benz has been acting up lately. i'm soo pissed at it i'm driving my Altima. i need help, it's driving me crazy.
first of all idle low. i dont know how (even if) i can adjust it. in D or R it rests at about 450-500 rpm, when it's that low the car shakes. in park it's about 750-800, perfect. i had bosch +2 platnums in there and i switched to the coppers. coppers made this noticably worse. But i notice that with the coppers i get better throttle response and 1-2 mpg more.
secondly, my rear end squeaks. horribly. i've inspected all the brushings and such and all look good. every time i lube it (with silicone spray) it lasts for about a day. then the squeaks come back.
also my front flex disk is shot, i replaced my rear one a few months back and that was easy. i took it to a shop and ask how much labor would be for he front disk. he quoted me $600 because HE said the tranny had to be removed. i'm calling BS on this one. since i did the rear i'm thinking that the front shouldnt be too hard. maybe though because of it's location.
the last 2 problems dont bother me as much as the low idle, it's embarassing to sit at a stop light with friend while your car's rumbleing and shaking.
Maintnance is all up to date pretty much, new cap/rotor, plugs, fuel filter, air filter, new radiator, thermostat. only thing thats a few years old are the plug wires, but are in good shape. i'm thinking that old engine mounts could contribute to this, but not sure. i dont even know how to inspect mercedes mounts.
Old Aug 3, 2005 | 08:39 PM
mike690003's Avatar
ex 300E driver
Have you replaced the rubber vacuum hoses yet?
Those old and worn vacuum hoses wreaked havoc on my car.
Old Aug 3, 2005 | 08:50 PM
jrmd01's Avatar
2005 E320 CDI
If it's just the shaking, then it's probably the motor mounts.
Old Aug 3, 2005 | 09:50 PM
AMG_Fred's Avatar
Mercedes-Benz w124
motor mounts won't cause low idle.... it may be ... i think its called the idle control valve
Old Aug 3, 2005 | 09:52 PM
neanderthal's Avatar
i want to say idle compensation switch, but i would be blowing smoke up your *** i think.
sorry bro.
how is your transmission?
and what happens when the fans engage (ie turn on your AC) at idle?
actually, after some thought i keep going back to idel compensation switch. dont ask me what it is or where it is. i stopped working on these cars a long time ago.
the front guibo (also known as hardy washer in mercedes circles), the flex disk is notoriously hard to do, although it can be done at home.
Old Aug 3, 2005 | 11:04 PM
Smokiesman's Avatar
93 300SE Rauch "Smoke"
The shaking and vibration when in drive is definately motor mounts! When in park smooth as can be!
Smokie
Old Aug 3, 2005 | 11:58 PM
Nandgopal's Avatar
Mercedes Benz 230e, 124
Idle
Had the same problem, and it was the Idle control valve! it sits below the intake manifold with rubber tube venting into the manifold in between the injectors on the upper side and a hose leading on to the fuel distrubutor on the other. It has a electrical connection and I think that is the problem, but have you checked the injectors also, a broken spring or a weak spring may also be the problem good luck!
Old Aug 5, 2005 | 03:28 AM
all rubber vacuucm hoses look fine, but thats just from looking at them.
tranny, despite it's age and miles. is in pretty good condition.
i'll take a look into this idle control valve. hopefully it's something easy.
also i notice that it only does this when it's warmed up to operating tempature.
i think i'm just going to get some more quotes on the flex disk.
to much trouble (and time) for me.
Old Aug 5, 2005 | 03:53 AM
this points to the idle compensation valve again. the computer is programmed to add fuel when the engine is cold, when its warm, it no longer adds fuel, manifesting this problem you have been having.
Old Aug 5, 2005 | 04:26 AM
thanks, i'll take mine apart and clean it tomorrow. i have some brake parts cleaner, would this be sufficient?
Old Aug 5, 2005 | 04:57 AM
paul9662's Avatar
1999 E55
low idle
check plug wires. may not be running on all cylinders
Old Aug 5, 2005 | 05:51 AM
funny you should say that, i get that feeling sometimes. almost like there's a misfire. i can auctually see the engine "surge" when it happenes.
Old Aug 5, 2005 | 01:49 PM
cap'n jasper's Avatar
W124
Neither the tranny nor the propshaft have to be removed. It's a 1hr job, max.
Old Aug 6, 2005 | 06:02 AM
ok tackled the ICV today (i think) lol i'm not sure what i disconnected and cleaned but it helped anyways. it had one electerical connection and 2 rubber hoses on each side.
took that off, didnt have any cleaner so i used brake parts cleaner. and sprayed it in the holes and shook it up untill i heard some parts "free up"
also the fluid was very dark that came out, i did that untill it was clear.
Didnt help my prolem however. car still shakes, so i'm thinking Mounts. the idle is not as low and the car starts after 1 or 2 cranks, so there was some improvement.
i cleaned out all my vaccum hoses (that i could see) and i found a loose one. went to kragen and bought new hoses and all that good stuff. that also improved the idle from fluctuating.
Used SeaFoam and sprayed that in the Throttle body and after that i noticed that there was more power taking off from standstill. also better passing power.
still however it's taking more and more to upkeep this car. as much as it would kill me to get rid of it that might be a possibility. I passed a 1996 Infiniti G20t for cheap, low miles and ok body (all it needed was a good wax and polish. it was Black) as much as i love Mercedes, Nissan is my first love and always will be.
Old Aug 6, 2005 | 07:20 AM
ksing44's Avatar
2010 VW Golf TDI
Lucky you
I think you are in luck. The fact that silicone spray makes a difference means that you can easily find the culprit. Just repeat your spraying technique, but only spray one site per application. You should be able to find the site of the squeak and then simply R&R that site. From my experience with squeaks, the hardest part is finding the place of origin. Since you have had success with stopping the squeak, you should easily be able to find it.
