Rotella T Synthetic Oil
Good stuff here. A few comments (may or may not be 100% accurate - take with a grain of salt.)
1) The factory oil filter on MB diesels won't filter soot - period. Mercedes expects the oil to suspend the soot. You need to change the oil before it reaches the limit of soot suspension, which is approximately 2% on all the older M-1 varieties, but over 4% for Delvac-1. (I'm not sure about the new M-1 EP's but I'm assuming they are 2% or so.) I've been told, without any confirmation, that Mercedes recommends the oil be changed when soot percentage reaches 2% regardless of what the oil can suspend (meaning you shouldn't go to 4% just because D-1 theoretically handle it.) My older OM603 engine is around 1% soot at 10kmi which works fine for me.
2) Bypass filters are a whoooooole separate topic. They do keep the oil near virginal at all times, assuming you change the toilet paper (no joke) cartridge every 2-2.5kmi on schedule. I'm personally not a big fan of these due to the frequency of TP change, and the fact you need to add a quart of oil with every TP change. This kills any cost savings over plain ol' extended OCI's in the 10-15kmi range (assuming UOA allows that in the first place.) Also, on most newer cars, finding space to install the bypass filtration system can be a pain. On a late 70's or early 80's Benz, there's room for a whole 'nother engine under the hood, so locating a spot to mount an extra canister is not a problem. But on a new CDI? Good luck... and the dealer/warranty question is not to be taken lightly either. Maybe add the setup after the warranty expires if MBUSA gives you any flak.
3) On the older (non-CDI) Mercedes diesels, the filter cartridges were allegedly 3x-4x oversize for the 'normal' 5-6kmi change interval, and are generally considered OK for extended drains to 10-20k or so assuming UOA numbers are good. I'm not confident of the accuracy of that assumption and I have NO idea what the new CDI filtration is like. I have been changing my filter with the oil at 10k, not changing the filter every 5k (I used to do that a long time ago but then was told the 3x-4x thing so I stopped. Hmmm.)
4) I have a PDF of my current OM603 oil analysis at this link. The first page shows a single 10k interval with Delvac-1. I have gone through 2 more 10k D-1 intervals since then and am about to complete a third... I need to update the PDF, huh. (Ooops.) I should have a good trend to display now. Soot averages 1% (approx) at 10kmi.
Finally... anyone see the specs on the new 2006 E420 CDI twin-turbo V8? Here's a thread with a link to some photos & techie details. Huge power, crazy fast... me want... probably not imported to the USA though.
1951 Caterpiller D6
Yeah Dave, GREAT stuff here. I'm not up to date on the automotive diesels. I'm a former heavy duty diesel man. I never thought about the physical location issues of the new cramped engine bay. Big problem! I'm used to walking in the engine bay of a Peterbuilt!
420 CDI is a monster! I'd love to rent one on my next trip to EU. The 320 CDI was such a blast. I'll bet the new one kicks A$$!.
