Exhaust Manifold Question
W124
Other than the exhaust manifold gasket are there any other flanges, donuts, seals, or gaskets I'll need to replace when I re-install the manifolds back in? It appears it may use some sort of flange at the base of the exhaust but I'm not sure of it. Plus is there any special way that I need to remove it?
lots of cars
Good luck removing the bottom bolts of the flange on the exhaust unless you have a lift or you want your back and arms to hurt for 2 days. LOL
Hope you have small arms and a long extension on your wrench.
