roof rack
My stealth hitch for my bike rack
For our 300E we have both factory and Thule racks, and neither makes use of the roof metal strips for mounting. There are no "mounts" that come with the car or mounts manufactured into the car.
Rather, the mount--which is part of the rack--has a pad that just rests on the roof and this assembly is clamped to the roof via a bracket that fits into the door cavity. You can see the marks for positioning the mount clamps stamped into the door opening sheet metal. No reason why these aren't the same on all W124 sedans.
Clearly, this isn't the way it works with T-wagons, as the roof rails are there. Thule for one makes brackets to clamp to the rails so Thule bars can be used. The wagen can be said to be the only W124 that "comes with rack mounts."
- G -
If my memory is serving me right now, I think I remember seeing threaded holes for mounting the OEM roof rack. As I said above, I couldn't imagine using an aftermarket roofrack on my E320, so I went with the hitch. The bolt on OEM version might have been cool.
Only exist, apparently, on coupes.
Sedans and wagons are W124s, too.
Yes, sedans, coupes and wagons are W124s, too.
ksing
thx for the compliments. the rims will be on show again at the oct 15th meet. i just went to brabus today and tried to get different center caps but alas no luck.
also i added a new mod for those people that think they cant have a sub in the trunk and enjoy it inside the car without haviing to loose their trunk to a box.
The original post was about sedans.
Clearly, information about coupes is irrelevant, and--as I stated--misleading.
I still think the hitch is the way to go, although I did have to rig some spacers to clear the rear skirt, since the hitch seems to be designed for an older W124. It also required drilling four holes into the trunk. That may be an issue for someone that is concerned about damaging his or her car.
