OK, ABS Sensors disconnected, what would you look at?
Old Feb 27, 2006 | 06:04 PM
NorCal124's Avatar
W124
Ok, as some of you know I found both of my ABS sensors disconnected and yes it does do that funky @SS locking grinding thing. My question is other than the sensors themselves, where else would you look to troubleshoot this issue. This is pissing me off. I bet my Aunt paid loot to get that ***** fix and their no good ******* mechanic just ghetto rigged the fix. Please, someone help me out.
Old Feb 28, 2006 | 01:53 AM
NorCal124's Avatar
W124
Anyone?
Old Feb 28, 2006 | 02:20 AM
CDP's Avatar
CDP
W124's
See Christian - This is what you get for buying you know what instead of fixing your car! lol
Old Feb 28, 2006 | 05:10 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
First I would suggest to replace all the ABS sensors. 2 in the front and 1 in the rear. Clean the counting wheels in the front thoroughly, many times they are full of brake dust and metal chips (brake disc wear) which may cause the sensors of misreadings. If this is not helping the next thing is the ABS controller.
Old Feb 28, 2006 | 03:09 PM
neanderthal's Avatar
i concur with bamburger.
you'd be suprised how often a good cleaning will "fix" something.
place car on jackstands
remove wheels
disconnect ABS sensors from each wheel (its a toothed ring) in the rear it might be on the differential input shaft
get an old toothbrush and clean.
reattach everything and test.
if that doesnt work, you check the wiring for continuity before deciding to replace the sensors
Old Feb 28, 2006 | 04:41 PM
NorCal124's Avatar
W124
SHUT UP CHRIS! You know why I needed to buy the uh..hum. But back to topic. After thinking about what bamburger said, I think I'm going to give a cleaning a try considering the sensors themselves run about $150 a piece. I also think a good cleaning would do some good anyways because of the organic pads that the W124 uses. Thanks bamburger. Chris, you're no help.
Old Feb 28, 2006 | 06:01 PM
ZedStyle's Avatar
Youngtimer
bamberger is like 'damn, i help you out, and you can't even spell my name right!'
poor, poor bamberger...
