Comment and Suggestions for Valve Stem Seal DIY Instructions
99 ML 320, 97 Porsche 993 C2S, 92 300E
I'm going to submit my instuctions for the DIY section of a forum I visit but before I do so I wanted to see if anyone had any suggestions for making my instructions clearer.
Valve Stem Seal Replacement M103 engine
General Information
Get the stem seal kit, new valve cover gasket, the two breather hoses that go from the valve cover to air cleaner housing and intake manifold (if you have never changed them they will be very brittle and probably break), two cans of brake cleaner to clean inside of valve cover and the oil pipe that sprays oil on the camshaft. Also get a meter of that clear plastic vacuum hose, you'll most likely see some under the air
cleaner housing that you'll want to replace.
Tools I send are as follows:
valve spring compressor
valve seal pliers
tool to connector air to spark plug hole & whistle
6 drain plugs
all these tools are made in the USA
Tools you will need: (based on how I did the job)
27 mm socket
½ drive ratchet
torque wrench-rocker arms 21nm, spark plugs 20nm, valve cover bolts 8.5 nm
good supply of shop air (capable of providing 75 psi), not sure how many CFM are required; mine has 61 gallon tank and puts out 11.3 CFM @ 90 PSI
small pencil magnet (sears craftsman)
sockets in a variety of sizes
Parts you need:
valve cover gasket
two breather hoses
valve stem seal kit-exhaust have yellow coated ring and intake have black coated ring, use install sleeve when doing intake
Remove Air Cleaner
detach breather hose from top valve cover to intake manifold and to air cleaner housing
remove three 10mm hex head screws that hold filter housing and disconnect electrical connector on intake and lift entire housing off with hose connected to the air filter housing
Fan Shroud
remove fan shroud, the part that you turn and pull out
Remove lower engine cover
Remove Valve Cover
remove valve and cover plate inside of valve cover that is held in place by phillips head screws and clean out with brake cleaner
remove bolt that holds transmission filler tube to head and push to side a little
plug six oil drain holes in head with plugs, stick each down hole about 2"
remove oil pipe and spray out with brake cleaner
pressure wash valve cover to blast off as much peeling paint as possible. I got most all of it off. Obviously this step is not necessary.
Changing Seals
I did one cylinder at a time as follows:
1-remove spark plug
2-screw in pipe with whistle on the end
3-turn crank slowly clockwise, keep turning until whistle starts to blows.
4-then turn real slowly and when the whistle stops you are at TDC, to be positive you can remove the tool with the whistle on it and insert a tiny streamlight or similar LED flashlight into spark plug hole and you will see the top of the piston
5-make sure the socket is on the crankshaft bolt and that the handle of the ratchet rests against the A/C compressor that way the engine can not turn when you supply air
6-if you removed the tool with the whistle on it you need to reinstall it remove the whistle from the top of the tool and attach air supply and pressurize cylinder
7-unbolt rocker arm
8-as you lift off rocker arm use pencil magnet to remove ball socket on each side, note orientation of ball socket for proper reinstall later
9-compress spring and remove valve collet halves with pencil magnet
10-remove valve spring
11-remove old seal with pliers
12-install new seal, use the right one for intake or exhaust and use the assembly sleeve on the intake seal, put a little oil on the seal to aid installation
13-reinstall spring & collets
14-do same for other side Air pressure should not be removed until both the valve springs are reinstalled, i.e., the collet halves are properly installed.
15-reinstall ball sockets, & rocker.
16-Go through same process for the rest of the cylinders
When you have done all cylinders remove the drain plugs, reinstall oil pipe, bolt holding transmission filler pipe to head, fan shroud, valve cover, breather hoses, air filter housing, & electrical connector to intake hose
__________________
General Information
valve seal pliers
6 drain plugs
27 mm socket
½ drive ratchet
Parts you need:
valve cover gasket
two breather hoses
Remove Air Cleaner
Fan Shroud
Remove Valve Cover
Changing Seals
1-remove spark plug
7-unbolt rocker arm
__________________
