Help w/ Oil Change 1995 E320 Cabriolet!!
Old Aug 6, 2002 | 09:12 PM
semandell's Avatar
1995 E320 Cabriolet
Unhappy Help w/ Oil Change 1995 E320 Cabriolet!!
Help, doing first oil change on our 1995 E320 Cabriolet that we recently purchased and for the life of me I can't find the oil filter! I have the removal tool and a repacement filter, but can't find it under the car (I removed the engine protection plate).
If you have any ideas please let me know asap!
Scott
Old Aug 6, 2002 | 10:08 PM
semandell's Avatar
1995 E320 Cabriolet
Never mind, i finally found it!
Old Sep 4, 2002 | 10:26 AM
Arthur Dalton's Avatar
Scott,
Be aware that the 104 eng. in your car has had a Tech. Service Bulletin from Benz that there has been an oil capacity change.
The original spec. was 7.5 l [ 7.9qt ] and the TSB has changed that to 7 l [7.4qt ] , w/filter..
Benz is recommending changing these specs in the owners manuals .
Another TSB has followed for dip stick reading modification.
This states that the ideal reading is now 1/2 way between the marks w/eng at operating temp.
I think this latter TSB is geared toward those using the suction system when changing oil , [ less llikely to know what is remaining in pan, so the first TSB is no help here ...]
