Performance Sway Bars ...
Old Mar 22, 2006 | 10:29 PM
sklasse's Avatar
Where can I get these ? so called Limo-bars or 500E
Old Mar 23, 2006 | 03:16 AM
NorCal124's Avatar
W124
From a Limo or 500E. Check out your local dismantler or if you want them brand new, see a dealership.
Old Mar 23, 2006 | 12:44 PM
Bigpete123's Avatar
1990 300ce
If heard a bit about these, but have questions-
Do they make a noticeable difference? (i.e. do the benefits outweight the hassle and cost)?
Are they a straight-up replacement?
Old Mar 26, 2006 | 10:04 PM
Smokiesman's Avatar
93 300SE Rauch "Smoke"
Pete! I put a set of OEM 500E bars that I got from Rusty and yes they do make a big difference!!!
Smokie
Old Mar 27, 2006 | 02:44 PM
NorCal124's Avatar
W124
Smokie, you need to lower your car w/ some vogtlands and tell me how they work w/ those kyb shocks/struts.
Old Mar 27, 2006 | 03:56 PM
AS Design's Avatar
Porsche 997 cabrio
I think you can use the E60 or 500E limited bar also.... I've seen it on this site..even though I can't understand what it says http://www.jauto.co.jp
Old Mar 28, 2006 | 12:01 AM
Smokiesman's Avatar
Naw!! plenty low for this old hillbillie! Any lower and I will need one of those lift seats to get my *** out of the car!! I like the KYB's but I like a stiff setup for the twisty roads we got here in the mtns. But it's all a matter of what each of us likes . Some likem stiff others likem soft ! Me I like a stiffie !
Smokie
Old Mar 28, 2006 | 02:22 AM
NorCal124's Avatar
W124
Do you think you can still achieve a lower stance w/ the KYB, vogtland combination or will the KYBs cause the car to retain a normal ride height dispite the lowered spring. I know people run lowering springs w/ stock shocks all the time, so my guess would be that KYBs should work.
Old Mar 28, 2006 | 02:33 AM
YNVDIZW124's Avatar
lots of cars
have any of you used koni shocks???....i have them on my mustang but it's not the same on a mb....
Old Mar 28, 2006 | 10:02 AM
CaliE320's Avatar
88 260 E
A member on here used Koni adjustables on his W124. They're alot more $$$ then Bilteins. I haven't seen him on here in awhile he was from the big island I think.
You could use lowering springs with stock shocks but again you could use nitrous on a Yugo. Anything is possible but is it feasable in the long run to save a few bucks? Trust me you're going to spend more money in the long run replacing those stock shocks .
~Cali
Old Mar 28, 2006 | 10:57 AM
Daez_Nutz's Avatar
1994 E500
The spring determines the ride height, not the shock.
Old Mar 28, 2006 | 12:58 PM
NorCal124's Avatar
W124
Yes, but I've seen scenarios where the type of shock/spring combination limits the lowering effectiveness of the spring (i.e. a gentleman w/ a W201 used HD bilsteins and vogtlands and it kept the level of his car not too far from factory ride height). His complaint may just be an issue spcefically w/ the W201 and not an issue with the suspension components. On another note, I'm not after KYBs because of the price. I want them because I know they work. Having had them in my Nissan and numerous friends running suspension setups with them, I'm confident in their ability to perform. My only concern is I know vogtlands lower the car relatively low, will I have the same issues that the guy w/ the W201 did?
Old Mar 28, 2006 | 01:11 PM
shadowgriffen's Avatar
is a German Tank
Smokie
Thanks for the laugh smokie
