1992 400E A/C Problems
Old Apr 2, 2006 | 11:05 AM
Koolwipski's Avatar
2006 E500 AMG PKG/2010 Camaro SS/RS - 2007 F-150 - 2007 Suburban
My first Post. I recently bought a 1992 400E, 97,000 miles for $5,250.00. I knew it had A/C problems. THe seller said his mechanic diagnosed a leaking Expansion Valve, my mechanic,after recharging w/dye says that since he cannot detect a leak on the compressor, expansion valve and other visible parts, it must be the Evaporator Core. (Quoted me $1,700.00 to replace - not a bad price, I think)
I recharged the system Friday at 7pm, Saturday, as late as 2pm, the air was ice cold, by 7PM - 5 hours later (24 hours after recharge) the system was empty, no pressure at all. Seems like this is a BIG leak? I do have a pungent funky odor in the cabin of the car (freon?)
ANyone experience a similar problem?
Other than the A/C the car is awesome. This is my second one, I sold a 1992 400E in 1999 after putting 100k miles on it. I had to have another one.
THanks
Steve
Old Apr 2, 2006 | 02:51 PM
Ron in SC's Avatar
99 ML 320, 97 Porsche 993 C2S, 92 300E
Yes, sure sounds like the evaporator. If you want to be 100% sure check the evaporator box drain tubes under the car and see if oil is leaking from them that is the color of the dye.
I just did this job and replaced all 6 vacuum elements and the blower motor on my friends 90 300D 2.5 turbo.
Yes the price you were quoted is very reasonable if it includes all parts.
Old Apr 2, 2006 | 05:01 PM
ebennz's Avatar
do a "search" on evaporator at www.mercedesshop.com and www.500Ecstasy.com
these sites are more serious and have better archives than here.
search is invaluable and these topics are well covered.
i had to have my evaporator replaced on my 400.
you bought a great car, BUT you will have to replace things and spend money on it. if you don't want to, sell it now,before "christine" takes a bunch of your money.
i bought a 2 owner 124.034 [400e] with 89k on it for $8000 in september '05. i've spent over $8000 on bring it current on maintenance and repairs!!!!
evaporator, radiator, waterpump,upper main engine wiring harness, lower main engine wiring harness, powersteering pump, rotors, brakes, real tune-up [caps and rotors], tranny service,front rotors and brakes, bosch euro lights and bosch clear corners
V-8's ain't cheap to keep.
peter
