Head Gasket Replacement
I was wondering if any of you have done your own Head Gasket Replacement, rather than having a Mechanic do it.
I was talking to a buddy of mine earlier, who is rather pretty good in that area of expertise has offered to help with the work.
So, I'm wondering what steps did you guys have to go through and do you have any advice, precautions, steps or anything that might help me out if I do decide to do this.
- Chris
Go to http://www.mercedesshop.com/ and then to the do it yourself, DIY, section: http://www.mercedesshop.com/Wikka/DoItYourSelf ; here you will find a M104 Head Gasket Replacement section with the following article.
on the M104 Engine
by Steve Brotherton
First Published in: ImportCar∞
It is a very in-depth article including Job Risks which is a way of saying it will be more complicated and cost more than you originally budgeted for.
Good luck and keep us posted.
kurt
1993 300CE Sportline
I don't know, man. Most people with a goal of long-term ownership will get a valve job at the same time. That's the kind of stuff I'd rather leave up to a professional. I know it's a lot of cash, but I'd say take it to a pro... Luckily it's more of a chronic problem, so you can drive around on it while you save up the money. It's just too important of a thing to risk it.
Yes valve job at the same time however if there is evidence of oil in the coolant lines replace them all. I replaced some, not all initially, but then the coolant line I did not replace initially at the heater in the back burst within 2 weeks. Green blood all over the garage.
This was the single most expensive fix to the car in one shot that i know of.
