Antenna Question/Problem
Old May 10, 2006 | 12:54 PM
G Man's Avatar
1992 Mercedes-Benz 500E (W124-036), 2004 W211 E55
I have a problem that I am experiancing after I completed installation of my lower wiring harness(alternator/starter) yesterday. Upon re-connecting the battery, the antenna mast extended without turning on the ignition or radio. I re-entered the radio code with the ignition on, turned off the radio, but the mast stays extended. The only way the antenna will retract, is to turn the key off. Before starting this project today, the antenna would only raise with the radio on. Any suggestions??? I want the antenna down when the radio is off, like it was before. Help.
