87 300e door panel removal??
Maybe I'm wrong, but from what I've read, there are more steps involved than that. I have a PDF document with pictures and step-by-step instructions if you end up needing more help... PM me with your email address. I haven't done it myself, but will be doing it in the next few weeks on my coupe.
lots of cars
Sorry, you do need to remove the cover from the seat control and remove the bolt holding the armrest....also you need to remove the linkage holding the door handle so you can take it out...also disconnect the flood light on the bottom...that should do it..
Yeah I did all of that and got it off...and no there are no more steps involved in taking it apart..all i did was unbolt the arm rest and pushed in and upwards..it poped off but i forgot to disconnect the light on the bottom..almost ripped the wire but its back in the car and fits perfect...o0h and the door latch...I just pushed it through the panel. Thank you so much for your help guys..really appreciate it and I know Im going to be needing more help in the future.
