question on front wheels
Old Jun 7, 2006 | 04:59 AM
DIMITRIAR's Avatar
300CE-24
i've recently noticed that the drivers side front wheel , sits about 10mm
further back than the passengers front wheel, is this normal for w124's?
The passengers one looks correct in its overall wheel arch balance,so if both front wheels should be exactly the same, is their provision for adjusting the front wheels back or forward on w124's?
Old Jun 7, 2006 | 10:21 AM
Makahveli's Avatar
"88 300CE- First Year Production
I heard for these rear wheel drive cars that, the driver side wheels are somewhat off centered to counter for the drivers weight, thats all I have.
Old Jun 7, 2006 | 11:31 PM
DIMITRIAR's Avatar
300CE-24
Thanks for your input Makahveli.
Pehaps a few w124 owners could have a look to see if they have a difference,by simply running a ruler or something about 20mm in width down between the tyre and the rear part of the wheelarch(lower body molding).This would be most helpful and interesting. thanks.
Old Jun 8, 2006 | 02:30 PM
mgw_300e's Avatar
Dora the Explorer
Mine's the opposite. My passenger side fron wheel is back towards the rear part of the wheelwell. I never measured it, but it's visually noticeable. I just assumed my alignment was bad and I'm waiting until I can afford to replace all the suspension bushings before I do something about it.
Old Jun 8, 2006 | 04:01 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
happened to me once on my car after someone rear ended me and caused me to spin out ona blind curve and the front wheel slammed the curb headon... result bent control arm.
put the car on a lift and see if the control arm is bent.
I have never heard of one wheel that is supposed to be further back than the other
Old Jun 8, 2006 | 05:02 PM
mgw_300e's Avatar
Dora the Explorer
I'll check it out, thanks.
Old Jun 8, 2006 | 08:06 PM
Jackd's Avatar
260E , 1989 (for now)
I just checked mine.
There is absolutely no difference between the right and the left side, Neither at the front nor at the back
Old Jun 8, 2006 | 10:15 PM
DIMITRIAR's Avatar
300CE-24
Thats interesting stuff guys,cause if i can get the drivers wheel the same as the other,than i should be able to fit a slighty larger tyre on without any rubbing on the inner wheelarch mould.I'm planning on fitting 225/55's on my 16 inch alloys,which are currently riding on 215/55's.
Old Jul 28, 2006 | 04:53 AM
jeffreyli86's Avatar
I have the exact problem and is taking the car for a check up tomorrow first thing in the morning..
Will let you guys know how I get on..
BTW, my car has done 55000miles, lowered on H&Rs and Bilstein Sprints, rolling on 17" rims (if these info matters )
Here's a couple pics..
Old Aug 3, 2006 | 09:04 PM
CLJ's Avatar
CLJ
300E
WOW! Nice Lights! Are they just a straight plugin HID conversion kit? Have the cops pulled you over? Tell me more!
Old Aug 4, 2006 | 09:22 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Yeah, I second that! I might get the symnic ebay lights and then HID kit! Tell us what you did!
Old Aug 6, 2006 | 12:19 PM
Sorry guys for the late reply.
The lights are Korean HID Conversion kit, I think I have 7000k bulbs in there. These lights are surely much brighter than my stock euros, yet they are not discruptive to other road users.
Back to the original topic. I've had my car checked out and I've said in another thread that the mech reckons the car has had a front end crash before (I knew it had, was my mom ). This caused some part to be bent back towards the car. The part I'm talking about is where the control arm connects to the chassis.. I don't know what the technical name is, but as my mech said, it's a flange.
Hope this helps.
